• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Corridor stuff
    146 Views, 3 Replies
    08-30-2006 03:24 PM
    This might be really dumb, but I was wondering if there was a way to change the colors in a corridor. With our plot styel, the magenta is really really thick and we always end up turning off corridor. I was wondering if there was a way to just change the colors.
    Also, I didn't see a separation of the elements for the corridors. I know with corridor surfaces, there's a breakdown of the major and minor contours and those could easily be changed, but I didn't see a breakdown at all for the corridors. The main reason this is a problem is because I'm trying to add slope arrows through my corridor and I can't turn off the corridor without turning off the slope arrows as well. Where would I go to see what layer each entity on the corridor on...I'm espeically looking for slope arrows and any other type of labels like that...
    Please use plain text.
    Employee
    Re: Corridor stuff
    08-30-2006 03:40 PM in reply to: chammett
    Look into code set styles these control much of a corridor display. As well
    the feature lines tab will help in controling the corridor display.
    wrote in message news:5313120@discussion.autodesk.com...
    Re: Corridor stuff
    08-30-2006 03:58 PM in reply to: chammett
    If you are using 2006, go to the codes tab in the Corridor Properties. Where the code set style is edit the style or make a new one. Change the Link style in the code set style to a color that you want. See attached picture.
    Civil Reminders
    http://blog.civil3dreminders.com/
    http://www.CivilReminders.com/
    sds
    New Member
    Re: Corridor stuff
    06-05-2012 10:05 AM in reply to: Civil3DReminders.com
    I just needed this information in civil 3D 2013 and it worked the same.  thank you!!!
