• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Accepted Solution
    Corridor Surfaces & Superelevation
    243 Views, 3 Replies
    02-26-2013 03:21 AM
    I have an alignement to which I have applied superelevation.
    The superevation has been applied and the alignment has been annotation and it shows the change from camber to superelevation on  the curves.
    However when I create a surface of my corridor it does not show the superelevation, the surface is showing a cambered alignment throughout.
    Any suggestions?
    I have created a new alignment, a new corridor and surface and still the same.
    Please use plain text.
    Distinguished Mentor
    Jay_B
    Re: Corridor Surfaces & Superelevation
    02-26-2013 04:42 AM in reply to: LOUISEBEST19
    Have you chosen a lane subassembly that supports superelevation and set "Use superelevation" parameters within that subassembly?
    Please see attached
    Jay
    C3D 2012 SP3
    Win 7 Professional 64 Bit
    Active Contributor
    w_davis
    02-26-2013 07:21 AM in reply to: Jay_B
    When creating the assembly I usually use crowned road and you can choose the slope (+ OR - 2% for me usually) or when choosing a lane you can also determine the slope.  So build the Assembly on one side and then copy it over. then when I create my surface using top links it usually shows the crowned road top along my alignment.
    New Member
    02-28-2013 03:55 AM in reply to: Jay_B
    Thats for this!
    I had chosed the UKIE Carriageway, which I presumed would be ok.
    When I check the settings box there was no option to change the working of the superelevation. There was one box that said superelevation with a number 6 after it. I presume this is a code.
    I started again with a new assembly.
    I used a standard DMRB template and adjusted it to suit my requirements, the carriageways on all these templates had the superelevation option which you showed.
