• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Brian Hailey
    Corridor Surface Boundaries (again)
    64 Views, 1 Replies
    12-07-2004 03:39 PM
    Ok, New subject, same topic. I have a corridor (same one I've been playing with) that says the boundary is ill-formed and to use the draw button to determine the location it crosses itself. The draw display doesn't show any errors. Is there any way to get the boundary into the drawing as a polyline so I can click, edit it, examine it, etc. to find these small crossings? Thanks, -- Brian Hailey LDT2005 C3D2005 XP Pro - SP 2 P4 2.8GHz 1.00 GB of RAM
    Please use plain text.
    *Angel Espinoza
    Re: Corridor Surface Boundaries (again)
    12-07-2004 04:05 PM in reply to: *Brian Hailey
    New subject, same topic, same respondent. You are correct. I have found that for some reason occasionally the verify polygon button returns with the message for an ill-formed boundary. Although, when you visually review the boundary it appears correct and the boundary will work perfectly fine. Angel Espinoza KETIV Technologies "Brian Hailey" wrote in message news:41b63f38_2@newsprd01... > Ok, > > New subject, same topic. > > I have a corridor (same one I've been playing with) that says the boundary > is ill-formed and to use the draw button to determine the location it > crosses itself. The draw display doesn't show any errors. Is there any way > to get the boundary into the drawing as a polyline so I can click, edit it, > examine it, etc. to find these small crossings? > > Thanks, > > -- > Brian Hailey > LDT2005 > C3D2005 > XP Pro - SP 2 > P4 2.8GHz > 1.00 GB of RAM > > >
