• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Corridor - Right angle corner / Bowtie
    916 Views, 7 Replies
    10-12-2012 01:13 AM
    Hi
    I have a Corridor issue - does anyone know how to fix the inside / outside corners of right angle corridor?
    Im doing a embankment lift and the client wants the corners neatly and not curved or champers.
    We often get a problem like, so help would be very nice! Also the outside corner should not curve. I can do it with gradings or futurelines, but if there is a design change i have to redo everything.
    See the assembly - this is only the first lift.
    Riaan
    Please use plain text.
    *Pro
    Re: Corridor - Right angle corner / Bowtie
    10-12-2012 01:35 PM in reply to: riaangroen
    feature lines is the best way to do it atm, sorry it's not more dynamic.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    sboon
    10-13-2012 09:51 AM in reply to: riaangroen
    Assuming that your alignment is at the inside of the berm the solution here is to add a very small radius curve at the corner, then add a single corridor section at the midpoint of that curve.  You will have to use the corridor section view/editor to adjust the assembly parameters for this new section.
    Joe-Bouza
    10-13-2012 02:34 PM in reply to: riaangroen
    riaangroen wrote:
    Hi
    Riaan
    So what kind of corner do you want?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Distinguished Mentor
    10-14-2012 01:18 AM in reply to: riaangroen
    I think Riann wants the corners to be sharp corners with no chamfers or roundings.
    As steve said, a very small arc with a frequency station at the centre.
    Here is a step by step post
    http://andrewscivil3dstuff.blogspot.com.au/2011/06/create-corridor-with-90-degree-bend.html
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    Active Member
    10-14-2012 06:50 PM in reply to: andrewpuller3811
    hi Andrew
    thanks for the blog - iv tried that before but does not quite work. It works well when the surface is close to the ground, but the higher you go, the more complicated it gets.
    Iv attached two more pics, second try at the corridor.
    The client wants a sharp outside / inside corner. I've tried the small radius, but as the lifts / raises progress, the bigger the arc gets on the outside.
    The alignment starts fro the inside going outwards, I've also tried going from the outside going in, but then I end up with a bowtie effect.
    This would be easier with offset polylines or gradings but there must be solution for this issue.
    I still need to go up 10 lifts / raise, so the arc is going to be massive at the end.
    Riaan
    Civil 3D
    Intel(R) Xeon(R) CPU
    X5675 @3.07GHz
    64-bit
    24GB RAM
    10-14-2012 07:40 PM in reply to: riaangroen
    You will need to have an alignment to target for the outside that does not have an arc in it.
    Offset your base alignment outward using the standard autocad offset command and then fillet the corner/s of the polyline with zero radius to remove the arcs. Create an alignment from polyline and use that as your outside target.
    Andrew Puller
    Civil 3d 2013 64bit
    Neilw
    10-15-2012 12:23 AM in reply to: riaangroen
    You have encounted a fundamental weakness in Civil 3D: it cannot dynamically model projected mitered corners. You can't do it with with corridors, offset alignments or gradings. The best you can do is minimize the fillet or chamfer by getting as close as you can to the final solution with featurelines or alignments and using them as corridor targets or for gradings.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
