• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    david.dixon
    Re: Corridor Modeling Question
    09-01-2011 10:24 AM in reply to: peterfunkautodesk
    yes
    David Dixon
    Senior Civil Designer
    xDaVeN Twitter
    Google+
    Please use plain text.
    Employee
    09-01-2011 10:54 AM in reply to: david.dixon
    Dave,
    I just tried it again in 2012 and it worked fine (once I actually hit the "Add" button to target the elevation).
    Peter Funk
    Autodesk, Inc.
    Peter Funk
    Autodesk, Inc.
    Valued Contributor
    david.dixon
    09-01-2011 10:56 AM in reply to: peterfunkautodesk
    let me try in 2012 then :smileyhappy:
    David Dixon
    xDaVeN Twitter
    Google+
    Valued Contributor
    david.dixon
    09-01-2011 11:03 AM in reply to: david.dixon
    no go.  The slope changes but the offset remains 3'.  I set "TargetParameter1" to target the bike path profile.  Does "TargetParameter2" under surfaces need to be set to anything?  Also, why is DeltaY set to "10" in the True definition portion? I can send you my drawing file as well if needed. It's around 5 MB.
    David Dixon
    xDaVeN Twitter
    Google+
    Employee
    09-01-2011 11:09 AM in reply to: david.dixon
    Send me the file directly... I have a different version of the PKT, but it works exactly the same for me.
    Peter Funk
    Autodesk, Inc.
    Peter Funk
    Autodesk, Inc.
    *Expert Elite*
    Joe-Bouza
    09-02-2011 09:37 AM in reply to: david.dixon
    ddixon wrote:
    < "BasicLaneTransition" >
    I try to stay away from sub assemblies with the word "basic" in the name. Most of thos are for demonstration and learning purposes as the help files often state.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Valued Contributor
    david.dixon
    09-06-2011 09:03 AM in reply to: Joe-Bouza
    Thanks again Peter for your assistance.  Creating a custom subassembly using Subassembly Composer was definitely the answer.  You have opened my eyes to a new and very powerful tool!  I owe you one.
    Best Regards,
    David Dixon
    xDaVeN Twitter
    Google+
