• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Corridor Gap
    171 Views, 4 Replies
    12-13-2012 12:00 AM
    Can anyone explein to me why gaps created where the regions of intersections joins? The daylight feature line stop connecting . See the attached picture. How i can resolve it?
    Please use plain text.
    *Expert Elite*
    sboon
    Re: Corridor Gap
    12-13-2012 12:04 AM in reply to: nikoue
    You should be able to grip edit the corridor region boundaries to extend them so that they touch.
    Re: Corridor Gap
    12-13-2012 12:10 AM in reply to: sboon
    They seem to touch. I must overlap the regions to connect them. And if i done that the intersection and corridor needs to update. When i update the gaps came back.
    Valued Mentor
    LisaPohlmeyer
    Re: Corridor Gap
    12-13-2012 05:51 AM in reply to: nikoue
    Although I like the intersection tool for adjusting profiles, I don't like how it creates the return alignments, we get gaps as well. Our work around to this is to modify the return alignments to have 10' tangent sections on each end.
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    Re: Corridor Gap
    12-13-2012 09:10 AM in reply to: LisaPohlmeyer
    The gaps usually appears between the curb return and the full section region. How it will help to modify the return alignment in the end?  The problem is not appear in the end. Also i want to ask you if you modify only the return alignments or you modify the offset alignments too? After your modifications you rebuild the corridor or you update regions and rebuild corridor? If you done the second the modifications still remaining?
    Thank you
