AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Corridor - Complex Merging
- Highlight
- Email to a Friend
- Report Inappropriate Content
I am using corridors to model a driving course. I have attached two images that show 2 scenarios. One is where an alignment loops back onto itself. The other is similar to a merging lane.
What are the best ways to handle these? I am having a hard time with the surfaces overlapping. I have tried using targets, but they don't work well.
Re: Corridor - Complex Merging
- Highlight
- Email to a Friend
First thing that comes to my mind is Intersection. I'm not proficient enough to help. Old school intersection can do this too, but in both cases you may want to break the alignment, looping alingments can be a problem.
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
- Highlight
- Email to a Friend
Looks simple enough. Split the loop into two alignments and corridors so that you can target from each one to the other. You will need a full width assembly and a half road - right side assembly. What do you plan to do for the lane crossfall in the merge area?
For the exit ramp its' pretty much the same thing. One full width assembly for most of the roadway and two half sections for the areas where the roadway splits.
- Highlight
- Email to a Friend
Why the two half widths? Do I use the right side section for road A and the left side for road B?
- Highlight
- Email to a Friend
Yes - the yellow piece will be built from the left section and the red piece from the right half section. The tricky bit is the section between them where the right lane of one road is crossing the left lane of the other one. You need to think about how you intend to handle the crossfalls in this area before you can determine how to build the assembly and corridor for this piece.
- Highlight
- Email to a Friend
Also, I assume this does not need to be an intersection, but rather just targeting an outside alignment of each corridor?
Thanks for the help.
- Highlight
- Email to a Friend
I would use the intersection wizard to start - it helps with locking the profiles together and adding the offset alignments you will need. You can skip the steps for building the offset profiles and the corridor, then work through the rest of it on your own.
If you can post a drawing with the alignments, profiles and basic template information then I'll try to find some time to build an example for you.
