• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Thoisington
    Corridor - Complex Merging
    324 Views, 6 Replies
    05-23-2012 01:54 PM
    I am using corridors to model a driving course. I have attached two images that show 2 scenarios. One is where an alignment loops back onto itself. The other is similar to a merging lane.
    What are the best ways to handle these? I am having a hard time with the surfaces overlapping. I have tried using targets, but they don't work well.
    Please use plain text.
    *Expert Elite*
    Joe-Bouza
    Re: Corridor - Complex Merging
    05-23-2012 03:02 PM in reply to: Thoisington
    First thing that comes to my mind is Intersection. I'm not proficient enough to help. Old school intersection can do this too, but in both cases you may want to break the alignment, looping alingments can be a problem.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    sboon
    05-23-2012 03:34 PM in reply to: Thoisington
    Looks simple enough.  Split the loop into two alignments and corridors so that you can target from each one to the other.  You will need a full width assembly and a half road - right side assembly.  What do you plan to do for the lane crossfall in the merge area?
    For the exit ramp its' pretty much the same thing.  One full width assembly for most of the roadway and two half sections for the areas where the roadway splits.
    Valued Contributor
    Thoisington
    05-23-2012 04:44 PM in reply to: Thoisington
    Why the two half widths? Do I use the right side section for road A and the left side for road B?
    *Expert Elite*
    sboon
    05-23-2012 04:55 PM in reply to: Thoisington
    Yes - the yellow piece will be built from the left section and the red piece from the right half section.  The tricky bit is the section between them where the right lane of one road is crossing the left lane of the other one.  You need to think about how you intend to handle the crossfalls in this area before you can determine how to build the assembly and corridor for this piece.Temp Merge.JPG
    Valued Contributor
    Thoisington
    05-23-2012 05:52 PM in reply to: sboon
    Also,  I assume this does not need to be an intersection, but rather just targeting an outside alignment of each corridor?
    Thanks for the help.
    *Expert Elite*
    sboon
    05-23-2012 06:18 PM in reply to: Thoisington
    I would use the intersection wizard to start - it helps with locking the profiles together and adding the offset alignments you will need.  You can skip the steps for building the offset profiles and the corridor, then work through the rest of it on your own.
    If you can post a drawing with the alignments, profiles and basic template information then I'll try to find some time to build an example for you.
