AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Corridor Boundary
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What's going on with this - I don't have an option for Daylight as a boundary.....using the same assembly as usual so I must be missing something very obvious but can't see it.......
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Re: Corridor Boundary
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've had this before too, I just worked around it. What I did was create a polyline boundary by copying the surface with the border turned on and then exploding it. Then add the boundary that way..
Might want to offset the border by .1 or .01 or something like that too..
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
dibr0804 wrote:..... by copying the surface with the border turned on and then exploding it. ......
FYI....you can extract objects from a surface. Just set the style of your surface to show the border, then while you have it highlighted. in the context tab in the ribbon you should see extract objects.....use that to extract the boundary. then add it as you said. saves time and headache......
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Are you sure you have catches everywhere? I have seen this when there isn't enough topo.
Two options:
1) Add another baseline to your corridor so then you will get the option "Corridor extents as boundary" option. You don't need a region. Dynamic
2) Create boundary from corridor externally and apply to surface. Not dynamic.
AutoCAD Expert Elite
AutoCAD Civil 3D 2013 Certified Professional
C3D 2013 (SP1)
C3D 2014 (Testing)
Win 7 Pro, 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You have Daylight Fill as an option but not Daylight. This suggests to me that you aren't creating the Daylight Feature line. Is it checked on in the Feature Lines tab?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is the tab - as mentioned its the same assembly dragged in as usual from a tool pallette; never had a problem in the past with this.....GRRRRRR
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for this Bruce - tried both and both worked fine
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am new in civil 3d.when i prepare a corridor its boundary suddenly goes away.kindly guide me???
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please note - adding a new question to the end of an old thread which has already been solved is usually referred to as a hijack, and is considered to be impolite. If you ask your question in a new thread I'm sure that someone will be able to help.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
ok really sorry steve actually new user
