• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    neilyj
    Corridor Boundary
    946 Views, 10 Replies
    03-27-2012 08:55 AM
    What's going on with this - I don't have an option for Daylight as a boundary.....using the same assembly as usual so I must be missing something very obvious but can't see it.......
    neilyj
    (No connection with Autodesk other than using the products in the world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    Distinguished Contributor
    dibr0804
    Re: Corridor Boundary
    03-27-2012 09:03 AM in reply to: neilyj
    I've had this before too, I just worked around it. What I did was create a polyline boundary by copying the surface with the border turned on and then exploding it. Then add the boundary that way..
    Might want to offset the border by .1 or .01 or something like that too..
    Valued Contributor
    emelendez
    03-27-2012 12:24 PM in reply to: dibr0804
    dibr0804 wrote:
    ..... by copying the surface with the border turned on and then exploding it. ......
    FYI....you can extract objects from a surface. Just set the style of your surface to show the border, then while you have it highlighted. in the context tab in the ribbon you should see extract objects.....use that to extract the boundary. then add it as you said. saves time and headache......
    03-27-2012 01:16 PM in reply to: neilyj
    Are you sure you have catches everywhere? I have seen this when there isn't enough topo.
    Two options:
    1) Add another baseline to your corridor so then you will get the option "Corridor extents as boundary" option. You don't need a region. Dynamic
    2) Create boundary from corridor externally and apply to surface. Not dynamic.
    Bruce Klug
    AutoCAD Expert Elite
    AutoCAD Civil 3D 2013 Certified Professional
    C3D 2013 (SP1) (HF 3.0)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    sboon
    03-27-2012 05:02 PM in reply to: klugb
    You have Daylight Fill as an option but not Daylight.  This suggests to me that you aren't creating the Daylight Feature line.  Is it checked on in the Feature Lines tab?
    neilyj
    03-28-2012 12:19 AM in reply to: sboon
    This is the tab - as mentioned its the same assembly dragged in as usual from a tool pallette; never had a problem in the past with this.....GRRRRRR
    neilyj
    neilyj
    03-28-2012 05:20 AM in reply to: klugb
    Thanks for this Bruce - tried both and both worked fine
    neilyj
    Active Member
    12-31-2012 04:48 AM in reply to: neilyj
    I am new in civil 3d.when i prepare a corridor its boundary suddenly goes away.kindly guide me???
    sboon
    01-01-2013 10:50 PM in reply to: Malikawan
    Please note - adding a new question to the end of an old thread which has already been solved is usually referred to as a hijack, and is considered to be impolite.  If you ask your question in a new thread I'm sure that someone will be able to help.
    Active Member
    01-02-2013 12:41 AM in reply to: sboon
    ok really sorry steve actually new user
