• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    Valued Contributor
    Copy Issue
    275 Views, 34 Replies
    01-15-2013 07:59 AM
    Hello There!!!
    i am trying to copy couple of manholes from one city map to another one. But, for some reason when i go to clipboard, and click on Copy with base point. Go on to the 2nd file and click paste. It doesnt work!!!!
    I am not sure, whats the problem? all the layers are on too...
    can anybody please help me ASAP??
    Please use plain text.
    Valued Contributor
    Re: Copy Issue
    01-15-2013 08:07 AM in reply to: shinysingh
    Everytime i try to paste onto the other file. it's asking for the insertion point. But it doesnt show after that. Under the command line, "its saying the Pasteclip Duplicate definition of Block ignored". I don't know why is it saying that?????
    *Expert Elite*
    sboon
    Re: Copy Issue
    01-15-2013 08:13 AM in reply to: shinysingh
    We need more information.  Are you trying to copy blocks or Civil3d structure objects?
    Valued Contributor
    Re: Copy Issue
    01-15-2013 08:14 AM in reply to: sboon
    No, its a block.
    Valued Contributor
    Re: Copy Issue
    01-15-2013 08:15 AM in reply to: shinysingh
    i clicked on a block and select similar and then copy with base point. when on to another drawing, click paste.
    But, nothing works.
    All it says is the" pasteclip duplicate definition of block XYZ ignored"
    Is there anyway i can paste the block from one drawing to the other????
    *Expert Elite*
    sboon
    Re: Copy Issue
    01-15-2013 08:21 AM in reply to: shinysingh
    So you already have a block with the same name in the destination file.  The blocks insertions that you copy and paste will therefore use that definition, instead of the one from the source file.  This means that the objects pasted may be at a different scale or look completely different than what you expect.
    Another possible problem would be if the block is Annotative, and your drawing scales don't match.  If the setting for display of Annotative objects at all scales is turned off then the blocks won't show.
    Valued Contributor
    Re: Copy Issue
    01-15-2013 08:26 AM in reply to: sboon
    the annotation visibility is turned ON on both the drawings, also the drawing scale is same in both of them.
    i can't just find the block when i paste it on 2nd drawing. its not small or pasted far away or something, its just not showing at all....
    P.S i don't think i have the same block n my destination file. But when i try to use the insert command, it doesnt show up either. and because there are soo many manholes in need to put on my destination drawing. i was prefering to just paste all of them at once from one dwg to the other...
    Also, i believe the drawing scales should match. Bcoz i just save as my destination file. But dint realised yesterday that the manholes were missing in my destination file...
    *Expert Elite*
    AllenJessup
    Re: Copy Issue
    01-15-2013 08:37 AM in reply to: shinysingh
    In the destination file do a Zoom Extents then a Zoom Object. When asked to select the object use a (L)ast selection. Enter a height that would show your block.
    You can also try a List with a Last selection and see what that shows.
    Valued Contributor
    Re: Copy Issue
    01-15-2013 08:43 AM in reply to: AllenJessup
    what do u mean by Last selection??? the block doesnt show on the destination file...
    i have tried turning off all the other layers.. and then tried zoom extents.. but i don't see anything..
    i think last time when i tried pasting the block on my destination, because it said pasteclip duplicate destination of block XYZ ignored.....
    I don't think so the blocks got pasted on the destination file...
    But the question is how do i paste it, so that it shows up on my destination file?????
    *Expert Elite*
    AllenJessup
    Re: Copy Issue
    01-15-2013 08:50 AM in reply to: shinysingh
    See this to explain the Last selection option.
    Maybe it did and maybe it didn't. The steps I outlined will show if it did.
    Can you paste the block in to a new drawing created from your template. BTW Is the block defined in your template?
