• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Converting .ctb to .stb plot tables
    268 Views, 5 Replies
    11-08-2012 07:01 AM
    I am doing a little trial and error on possibly converting a drawing from .ctb to .stb.  When we start a new drawing, it will be started using named plot styles so it shouldn't be an issue.  But there are times when we receive a drawing from someone else and need to convert it.
    The first thing I did was convertctb to create a conversion .stb.  Then I used convertpstyles to convert the drawing to named plot styles.  For the plot style table I chose the conversion .stb I just created because it needs a color mapping table.
    But I don't want to use the converted .stb table, I want to use my company plot style.  So when I am in layer properties manager, Plot Style is still grayed out and I can't change it.
    When I type in pstylemode, the default is 0 (read only).  How do I change it so it's not read only and I can use my own plot style table?
    thanks. Caryn
    Please use plain text.
    AllenJessup
    Re: Converting .ctb to .stb plot tables
    11-08-2012 07:14 AM in reply to: mnyrac
    Active Contributor
    11-08-2012 07:16 AM in reply to: AllenJessup
    Right.  And I've seen the link you've listed.  I have followed what I thought were the correct steps, but I still keep getting my plot styles read only.
    AllenJessup
    11-08-2012 07:24 AM in reply to: mnyrac
    Is your company plot style a CTB or an STB? If the pstylemode is set to 0 that is correct for an STB. I don't know why it's still grayed out in your layer manger. But I don't think changing the variable will do that. You can toggle pstylemode by using convertpstyles, but I don't think that's what you want.
    Check your page setup manager and see what plot style is set.
    Allen
    Active Contributor
    11-08-2012 07:28 AM in reply to: AllenJessup
    We are beginning to use .stb but we will have to convert from .ctb on occassion.
    I went to pagesetup and modified my current page setup to use my .stb (instead of none like it was set at) and that worked.  Thanks!
    Caryn
    AllenJessup
    11-08-2012 07:30 AM in reply to: mnyrac
    You're welcome. Glad it helped.
    Allen
