• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    silvernich
    Converting 3D Poly to a Feature line
    258 Views, 3 Replies
    10-25-2012 01:10 PM
    Hello all,
    So I am attempting to create a simple grading daylight. I began with a 3D Polyline that has only 2 verticies. When I "Convert Feature Lines from Objects," it creates a feature line with 4 verticies. The 1st and last have the initial elevations from the 3D Poly, but the 2 new verticies seem to be pulling elevations off the surface below where I am working.
    My questions are: 1) why are new verticies added? 2) can this be prevented?
    I know that I can overwrite the slopes in elevation editor, but this seems like an unnecesarry extra step.
    Thank you for your input
    Civil 3D 2011/2013 User
    Please use plain text.
    Re: Converting 3D Poly to a Feature line
    10-25-2012 02:15 PM in reply to: silvernich
    When you Create Feature Line from Objects, be sure you turn off the option to Assign Elevations.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    AllenJessup
    10-26-2012 05:41 AM in reply to: silvernich
    Or if you need to assign elevations uncheck ie.PNG in the Assign Elevations dialog box.
    Allen
    silvernich
    10-29-2012 04:12 PM in reply to: AllenJessup
    Thank you for your comments. I will see when I run into it again if I can give a more concrete example as both of your suggestions I believe I was already doing.
