• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Accepted Solution
    Contour lines display
    357 Views, 4 Replies
    09-19-2012 12:38 PM
    I am having problems viewing my contour lines after I create a surface. I create the surface using points.  The contour lines will show up when I create the surface. After I close the program or the drawing, I am not able to see the contour lines again. The contour lines are on in the surface style.  How can I see the contour lines without creating the surface again?
    Please use plain text.
    *Expert Elite*
    neilyj
    Re: Contour lines display
    09-19-2012 01:04 PM in reply to: rvandever21
    Do you have Level of detail switched on??
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Active Member
    09-19-2012 01:24 PM in reply to: neilyj
    Where can I find the level of detail?
    *Expert Elite*
    neilyj
    09-19-2012 01:33 PM in reply to: rvandever21
    see screenshot - can you post the dwg if this doesn't solve the problem??
    neilyj
    Active Member
    11-13-2012 01:23 PM in reply to: neilyj
    That worked. Thank you.
