AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Contour labels visibility
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi:
I am trying to make my contour labels visible, indepently of the Visible status of the contours in the surface style of the original surface that I am working on. I have to do this due the final topo looks strange in the borders so I am displaying another contours -that do not have elevation- and make look the drawing better. The problem is that if I turn off the Visible property of the contours, the labels turn off even that they were created in a different layer and attached to a label style with its own layer property.
Just in case you need more details, do not hesitate to give me a shout.
Thanks in advance
Rafael Moreno
Re: Contour labels visibility
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Use a layer within the surface style for your contours and then you can simply turn that layer off and the contours labels will remain.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Brian:
Thank you very much for the quick response. I tried this and it works, the problem is that I do have several objects and all of them attached different Surface Styles. These surface styles call the same layers to display the contours so if I turn off the layers, the contours of all objects are going to disappear. I know that you told me that I have to create antoher layer for this surface but in this case I have to create several for the other surfaces.
Is there another solution?
Rafael Moreno
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Explode the labels.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Brian:
Thanks for your answer. I will keep this as a solution. I have a quick question...do I need antoherh thread?
Rafael
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
arcallupe wrote:Explode the labels.
NOOOOOOOOOOOOOOOO
Don't explode the labels! If your surface changes, the labels won't update. Simply copy the surface style and change the layers the contours are using. Do this as many times as necessary.
NEVER EXPLODE ANYTHING IN CIVIL 3D EXCEPT AS A LAST RESORT! The only last resort I would use is, "I have to get this out today and I don't understand how the program works so I'll explode it for now but as soon as I get a chance I'll figure out a way to do this without exploding".
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sometimes I think we need a thumbs-down 'anti-kudo' button for some posts.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
