• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    windycityengineer
    Contour Texts
    240 Views, 4 Replies
    11-16-2012 08:55 AM
    The contour lines themselves are in model space. The contour texts are in paper space. How do I make the line hide under the  text? I have attached of a similar drawing done by someone else. Any help is greatly appreciated.
    Thank you,
    WindyCityEngineer
    Please use plain text.
    *Expert Elite*
    Re: Contour Texts
    11-16-2012 09:06 AM in reply to: windycityengineer
    You are in an unusual situation to have the contour labels in paper space.
    However, you could consider using wipeouts, although I generally despise them.  My preffered option would be to use the background mask option in Mtext.
    If this text is actually Mtext, you can select them all, go to your properties, and add the background mask. I like a factor  or 1.05, and be sure to select 'Use background color'.mask.png
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Expert Elite*
    Re: Contour Texts
    11-16-2012 09:10 AM in reply to: windycityengineer
    If your text is regular TEXT, not MTEXT, you need to convert it first.  The Express tool will do that, but you have to run it one by one, or it will combine all the labels into one piece of MTEXT.
    The attached lisp will convert all the selected regular TEXT into MTEXT, leaving them as separate entities.  Be sure to set the Mtext width to zero after you convert, and then set the background mask.
    *Pro
    Re: Contour Texts
    11-21-2012 11:06 AM in reply to: windycityengineer
    Since we are using civil 3d software why not use the contour lines to create a surface and use C3D contour lables to lable the contour lines.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    *Expert Elite*
    Joe-Bouza
    Re: Contour Texts
    11-21-2012 06:21 PM in reply to: dgordon
    Very diplomatic of you , Dan :smileywink: my thoughts were in other arena's
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
