AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Contour Texts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The contour lines themselves are in model space. The contour texts are in paper space. How do I make the line hide under the text? I have attached of a similar drawing done by someone else. Any help is greatly appreciated.
Thank you,
WindyCityEngineer
Re: Contour Texts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You are in an unusual situation to have the contour labels in paper space.
However, you could consider using wipeouts, although I generally despise them. My preffered option would be to use the background mask option in Mtext.
If this text is actually Mtext, you can select them all, go to your properties, and add the background mask. I like a factor or 1.05, and be sure to select 'Use background color'.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
Re: Contour Texts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If your text is regular TEXT, not MTEXT, you need to convert it first. The Express tool will do that, but you have to run it one by one, or it will combine all the labels into one piece of MTEXT.
The attached lisp will convert all the selected regular TEXT into MTEXT, leaving them as separate entities. Be sure to set the Mtext width to zero after you convert, and then set the background mask.
Re: Contour Texts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Since we are using civil 3d software why not use the contour lines to create a surface and use C3D contour lables to lable the contour lines.
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
6Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Re: Contour Texts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Very diplomatic of you , Dan
my thoughts were in other arena's
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
