• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Contour Lines not displaying correctly.
    415 Views, 6 Replies
    10-16-2012 06:53 AM
    What is the easiest way to correct contour lines when they don't display correct?   Adding points, deleting points, switching edges...
    See everything circled in orange on attached pdf.
    Please use plain text.
    Valued Mentor
    Re: Contour Lines not displaying correctly.
    10-16-2012 07:00 AM in reply to: SSAuburn
    Assuming that is a corridor-related berm you've created, it looks like you have some targeting issues, maybe? Hard to tell.
    Active Member
    10-16-2012 07:02 AM in reply to: castled071049
    What do you mean by target issues?
    Valued Mentor
    10-16-2012 07:06 AM in reply to: SSAuburn
    For example, in the area marked "Two C Pipes", the contour issues look like the something is amiss, perhaps, with the berm grading back to existing grade? Lots of things can be causing your problem, I'm just guessing at one that might be a cause.
    *Expert Elite*
    johnm
    10-16-2012 07:46 AM in reply to: SSAuburn
    If this is an exisitng topo or a feature line or a grading design I would be fixing the breaklines and/or removing the bum shots creating these issues. What I see in your file is what I see in our files when the surveyor used points in the surface for objects sticking out of the gound (or underground) like top of hydrants, top of headwalls, (pipe inverts) etc. or when breaklines are required but are not modeled.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    *Expert Elite*
    johnm
    10-16-2012 07:48 AM in reply to: johnm
    If you added contours to the surface definition I would make sure that you have the Minimize Flat Areas option checked. This should fix the errant contours going over the flat areas.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    Active Member
    10-16-2012 09:58 AM in reply to: SSAuburn
    Answer to my own question:  I changed the contours to show every 1.01 and 5.05 instead of 1 and 5.
