I have a proposed grade surface. How do you label contours? Is there a way to add slope data (grades) to the plan?
Yes! Right-click your surface ==> surface-properties ==> goto tab "Analyse" and set ranges for slopes to get differentiated + set the surface-style properties for how analyzation data hase to be presented.
HTH, - alfred -
.... or you can just use surface labels
neilyj (No connection with Autodesk other than using the products in the real world)
