AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Contour Label Background Mask
- Highlight
- Email to a Friend
- Report Inappropriate Content
I have read through all of the other solutions on this issue and none seem to address my problem. No matter what I do, I cannot get my contour label to mask the contour line that it sits on. I have no problems creating contour lables for my surface (whether using single, multiple, or multiple at interval options). I have set my contour labeling defaults to not display the contour label line, as well as set Label Mask Type to Contour Line Only. Unde contour label style under Layout>Border>Background Mask, this is set to True. Not sure what is going on here, any suggestions?
Re: Contour Label Background Mask
- Highlight
- Email to a Friend
Have you tried selecting a contour label, right clicking and changing the Display Order to Bring to Front? If so, when you go to the contour label layout settings and set the Border Visibility to True do you see the border for the masking?
C3D 2012 SP1, Win XP Home
- Highlight
- Email to a Friend
Yes, I have tried Bring to Front; doesn't seem to do anything. And yes, when I set the Border Visibility to true, there is a border around the labels. I've tried both on, both off, and each individually on with no success...
- Highlight
- Email to a Friend
Land Consultants
Civil3D 2012 (Service Pack 2.1)
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
- Highlight
- Email to a Friend
Sjg, tried creating a whole new label style to no avail... This is my first time using this feature with Civil 3D; this is something that should be possible right? To have your contour labels cover up your contour lines?
- Highlight
- Email to a Friend
Land Consultants
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
- Highlight
- Email to a Friend
Hope this attachment works. I imported 3d polylines from another road design program, which were my surveyed cross sections for the project. Used these as breaklines to create my surface, with a 3dpolyline surrounding my survey data as a boundary, then added the contour lines. This is a survey of a mountainside for a proposed 3 mile logging road (single lane, low volume unpaved road).
- Highlight
- Email to a Friend
Also, as a note... I have Autodesk Design Institute Press "AutoCAD Civil 3D 2009 Procedures and Applications" reference. It came with a CD with examples, I used thier 3D surface modeling procedure they laid out there which is essentially what I am trying to do. Following their example, when I get to labeling the contour lines I run into the same problem in their drawing. Makes me think that there is something going haywire in my global Civil 3D settings or something.
- Highlight
- Email to a Friend
Your Visual Style is set to Conceptual. Change this to 2dWireframe and the masks work as expected.
- Highlight
- Email to a Friend
Ahhhhhhhh.... That did the trick! Did not even think of this, thank you!
