• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Re: Contextual Ribbon Command Pick Question
    02-25-2013 01:59 PM in reply to: SethHall
    Technically it is working but i have several users that are affected by this and i don't want them to have to update thier stuff for this one little problem. There has to be a toggle or variable some where that holds this... ???
    Werid.. And Thanks to everyone for you help.. Maybe in the future?
    Please use plain text.
    Distinguished Mentor
    02-26-2013 04:31 AM in reply to: ThomasGlidewell
    If you have both arg files, you could have a look through them and compare the various bits and pieces.
    Make a copy of them before having a look, then open them in notepad. The first part (of the one I have here anyway) is a registry file which stores all the settings for a profile that gets placed in the registry. The second and third parts are XML files which store the user interface settings like the ribbon, tool pallettes etc.
    If you copy the various parts of the two arg files into seperate new notepad documents, you can compare them using a file comparer or other program to check which settings are different. Be aware thought there is lots of info in the arg file, so you might be looking for a while, plus you might find heaps of settings different that have nothing to do with your issue.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
