• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Comparing multiple surface volumes
    333 Views, 8 Replies
    10-18-2012 08:45 AM
    Hey
    I have a big hole in the ground in my model.  Its easy to get the volume of cut with C3D.  But I have a topsoil layer, weathered rock layer and then solid rock, I basically need to break them down into different volumes.  The way I would normally do it is calculate the topsoil, then work out the weathered rock and minus the topsoil, then for solid rock cut I minus the topsoil+weathered rock.  Is there a better dynamic way of doing this?  I have attached the 3 volumes I need for info
    Please use plain text.
    Joe-Bouza
    Re: Comparing multiple surface volumes
    10-18-2012 11:32 AM in reply to: bigmaz
    does each  layer have a constant datum?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    neilyj
    10-18-2012 11:53 AM in reply to: bigmaz
    Have you tried volume surfaces egl vs total excn model, base topsoil vs total excn, base weathered vs total excn. You will still need to do a trivial calc to compute the topsoil and weathered volumes and the rock volume is direct from the model.
    Not sure that this is any better than your current method though but you can produce pretty pictures.
    you'd need to create models including the side slopes for each horizon to directly report volumes which is probably more hassle than it's worth.
    neilyj
    (No connection with Autodesk other than using the products in the world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Joe-Bouza
    10-18-2012 12:01 PM in reply to: neilyj
    Thats where I was heading with one twist. If the datums are constants you can tweak the FG build elevation  and one volume surface could be used for the three quantities.
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    neilyj
    10-18-2012 12:07 PM in reply to: bigmaz
    Looks like a quarry or openpit mine
    neilyj
    Joe-Bouza
    10-18-2012 08:05 PM in reply to: neilyj
    Duh...
    Run an alignment through it, sample lines , sections compute materials! ( no extra surfaces required)
    Dang I hate when I only think vertically
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    neilyj
    10-19-2012 02:06 AM in reply to: bigmaz
    I'll give this method a try although when using it the sample line spacing will need to be tight to minimise errors inherent in a sectional method.
    neilyj
    New Member
    11-03-2012 09:36 PM in reply to: neilyj
    If it is a quarry or open pit  then the sectionsmethod is suitable. True, it may generate some kind of minimum error, however the sections are generated automatically and give you the chance to give strictlytrack to the mining and monitors the floor levels.
    I have compared the results of the calculated volumes between two triangulated surfaces using sections and other programs as Terramodel, Surpac, Surfer, etc.. The results are very similar.
    neilyj
    11-04-2012 08:18 AM in reply to: AlexanderSchmidtObermoller
    If the baseline for the sections is dragged and the sections run at 90 degrees to the original line this will give a good check on the volumes - only in a quarry/open pit situation, no good for roads etc
    neilyj
