• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Re: Compare Points Perpindicular to Surface
    02-12-2012 09:54 AM in reply to: TerryDotson
    Here's another third-party option:
    http://www.quuxsoft.com/SincpacC3D_Help/SP_DisplayPoints.htm
    You should be able to also manage it in C3D without third-party help, using techniques like the one Jeff mentioned above, but it's a lot more time-consuming.
    Sinc
    Please use plain text.
    andrew.normore
    02-18-2012 11:42 AM in reply to: andrew.normore
    Just a little update. After trying and combining the suggestions everybody posted I have found a way to do this that gives the same results as terramodel.
    Import as-build points (CSV) into drawing. Elevate points to surface used for design DTM. Export points to a new CSV. Copy elevations from one elevated points CSV to the as-build point CSV, subtract the elevation differences and you have all the deltas for each individual point.
    For display, I create a new CSV with the deltas as the description, import into C3D and display the description.
    Thanks everybody for the help and suggestions. I would not have figured this out without them.
    Windows 7 x 64
    Dell Precision M6600 Mobile Workstation
    16 GB Ram
    i7 @ 2.5 ghz
    Civil 3D 2012 SP 1
    Civil 3D 2011
    Autodesk Inventor 2011
    AutoCad Map 3D 2011
    Joe-Bouza
    02-18-2012 12:54 PM in reply to: Sinc
    I didn't read the rest of the post but those results are the same as updating elevation from a volume surface of EG vs As-Built.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    neilyj
    02-19-2012 02:13 AM in reply to: andrew.normore
    The results will be the same but you will need to do some manipulation with points if you want to get the differences tabulated i.e. level differences at specific locations
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
    256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    02-20-2012 02:05 AM in reply to: Joe-Bouza
    The confusing thing about that is you need additional points.  Typically, you don't want to change your Survey point elevations.  So you don't want to just select your Survey points and adjust their elevations to match a Volume surface.  And creating copies of those points just adds clutter.
    But there are options...  As I said, you may not NEED third-party support like what we and Terry offer, but it can make your life much easier...
    Sinc
    andrew.normore
    02-20-2012 03:55 AM in reply to: Sinc
    In the method I described earlier, the dealings is more with the CSV's than with the points in the drawing. You elevate them once and then delete them as soon as you export. I have tried some third party software and i can not find anything that will generate the delta's and produce a report or points with attributes that represent the deltas.
    Windows 7 x 64
    16 GB Ram
    i7 @ 2.5 ghz
    Civil 3D 2012 SP 1
    Civil 3D 2011
    AutoCad Map 3D 2011
    neilyj
    02-20-2012 04:12 AM in reply to: andrew.normore
    Copying the required points to a new point group e.g. Deltas and then elevating to the TIN volume surface (might have to create a new surface and paste the TIN volume surface into it for this to work) will allow you to create a C3D table of XYZ of the points of interest where Z will be the delta value.
    If you need this in Excel then C3D tables do not lend themselves to doing this unlike vanilla ACAD tables. It is possible by exploding the table and using a lisp to create a vanilla ACAD table and then exporting to Excel.
    neilyj
    andrew.normore
    02-20-2012 04:15 AM in reply to: Sinc
    I do not create a TIN volume surface to complete this process. I just simply elevate the points to the surface I used to create the DTM and export them, then compare them to the points taken in the field. It is a very simple way to do this. Creating a TIN volume surface seems like an unneccassary step in the process.
    Windows 7 x 64
    16 GB Ram
    i7 @ 2.5 ghz
    Civil 3D 2012 SP 1
    Civil 3D 2011
    AutoCad Map 3D 2011
    Joe-Bouza
    02-20-2012 04:16 AM in reply to: Sinc
    Not for nothing but a desire to not make extra points sounds silly -Not saying Terry's and your app dont look useful, they seem very usefull.
    But..... Do you want to save the changes to the file (yes / No)
    Choices, life is all about choices
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    andrew.normore
    02-20-2012 04:21 AM in reply to: Sinc
    I agree. Life is about choices. What would be ideal is a report than can be created where you select the surface and the points you want to compare and it spits out an xls worksheet with the required info. I have been speaking to some people who say this may be possible in the future but I have not had any positive results.
    For me it's about keeping it simple. Importing, exporting, and deleting points is a very simple way to get this task done. However, I would much rather see a solution that is specifically designed to produce these results without creating extra points or surfaces.
    Windows 7 x 64
    16 GB Ram
    i7 @ 2.5 ghz
    Civil 3D 2012 SP 1
    Civil 3D 2011
    AutoCad Map 3D 2011
