• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Combining a corridor surface with another surface
    158 Views, 4 Replies
    03-16-2009 06:44 AM
    I have a corridor that begins on my existing surface and ends on my proposed surface. I am trying to have my corridor surface combine with the proposed surface. I edited my corridor properties to have it reference the proposed surface at the station where the centerline hits the edge of the proposed surface, but the corridor is not perpendicular with the edge of the proposed surface causing the corridor surface to be referencing my existing surface in a small area on one side of the corridor when it should be referencing the proposed surface and vice versa on the other side. When I paste my corridor surface into the proposed surface this creates a small ditch in my slope. What can I do to fix this problem?
    Please use plain text.
    Active Member
    Re: Combining a corridor surface with another surface
    03-18-2009 06:30 AM in reply to: Kohntopp
    Does anyone have advice?
    Distinguished Contributor
    03-18-2009 06:40 AM in reply to: Kohntopp
    Can you post an image showing the problem area?
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 2
    AutoCAD MEP 2011 Ver. 3
    Windows 7 Pro 64bit
    Active Member
    03-18-2009 06:47 AM in reply to: Kohntopp
    see attachment
    03-18-2009 07:07 AM in reply to: Kohntopp
    Attached image for better clarity. Basically you will need to have a region with one side targeting the proposed surface. Then start another region when the other side needs to start targeting proposed
    Glenn Pope
    Windows 7 Pro 64bit
