• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    C3D_TomR
    Re: Combining Multiple surfaces to create Final Surface - Boundary issues
    11-30-2012 02:09 PM in reply to: RobRaminsh88
    Creat another surface "Void-1". Paste the non-roadway surface into it. Add a boundary that matches the void area inside the roadway. Paste the three surfaces into your combined surface in this order: "Non-roadway surface", "roadway surface", "Void-1 surface".
    Please use plain text.
    *Expert Elite*
    neilyj
    12-01-2012 03:44 AM in reply to: RobRaminsh88
    this is the approach I'd take although just check that the triangles form correctly at all common boundaries. They usually do but occasionally you might have a gap which can be closed by adding a show boundary.
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
