• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    RobRaminsh88
    Combining Multiple surfaces to create Final Surface - Boundary issues
    337 Views, 11 Replies
    11-28-2012 01:53 PM
    Hi Everyone,
    I am creating my Final Grading surface with from 2 surfaces - a proposed road surface and a proposed grading surface.  (Note of roads within the road surface)
    The issue is that when I paste the proposed road surface (that consists of several looped sections) over the proposed grading surface, the proposed grading surface within the looped road areas dissappears.
    I have tried several options using boundaries for the inner looped areas on my road surface, and has altered my order of opterations for my final surface edits, and many other things also.
    I have attached an image for your reference.
    Any ideas would be greatly appreciated.
    Thanks.
    Rob
    Please use plain text.
    Valued Mentor
    Re: Combining Multiple surfaces to create Final Surface - Boundary issues
    11-28-2012 04:11 PM in reply to: RobRaminsh88
    If the roads were created with separate corridors (and, hence, separate surfaces from them as well), you can paste each surface individually into the proposed grading surface without creating the voids.
    Other methods will work but are considerably more labor intensive.
    *Expert Elite*
    11-28-2012 04:46 PM in reply to: RobRaminsh88
    Have you tried pasting the road first then the grading?
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    *Expert Elite*
    11-29-2012 07:22 AM in reply to: RobRaminsh88
    Just change snapz=0 to snapz=1 and try it.  You have 3D polylines for some reason, not sure.
    Bill
    *Expert Elite*
    11-29-2012 07:42 AM in reply to: castled071049
    The only foolproof way I can think of is to split up either the roads or the grading surface to multiple smaller surfaces, then paste together onto the finished grade.  (Paste the big one first, then the multiple small ones.)  Either way will work: split the roads up so they don't loop, or split the grading surface up so it fits inside the loops.
    As said earlier, this is labour intensive.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Pro
    11-29-2012 08:04 AM in reply to: RobRaminsh88
    whatever grading or spot elevations or contours that where used to add to the grading surface, add them to the road surface instead and have one surface with no need for pasting.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Active Contributor
    RobRaminsh88
    11-29-2012 11:49 AM in reply to: RobRaminsh88
    I may be missing something, but what is the "snapz" command?  My Civil doesn't seem to recognize it?
    Active Contributor
    RobRaminsh88
    11-29-2012 11:50 AM in reply to: mathewk
    This didn't make any difference - I tried several orders, which all had different effects, but none of which were benificial to sovling my problem.
    Active Contributor
    RobRaminsh88
    11-29-2012 11:52 AM in reply to: castled071049
    This worked the best of the solutions thus far, but didn't entire fix the problem.  Thanks.
    *Expert Elite*
    11-29-2012 12:08 PM in reply to: RobRaminsh88
    I think this is one for the wish list.
    Ideally you should be able to add a hide boundary to your roads surface (possibly you already have one there) and then when you do the paste it should leave the original data in that hide location.  This is what you tried first of all, right?  And it doesn't work? Instead it is replacing data with no data, if I understand you correctly.
    It should work as you wanted it to, I can't think of any reason why not.  What do others out there think?
