AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Cogo point default label and layer settings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am using Description Keys for all my points that I bring in from surveying in the field. Any point that does not have a specific descriptor key ends up on a specific layer with a specific style that I cannot figure where to set. I have gone through my point default settings as stated in other postings but all seem to be set correctly mostly to <none>. I have gone through my Point Group settings without finding the culprit either. I can easily change the settings as I only have a few points that do this but I want to find the issue. Any help is greatly appreciated.
Re: Cogo point default label and layer settings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Typically I set it in the Create Points dialog within my template, and then forget about it after that.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Settings tab of Toolspace, Point, Commands, right click Create Points, Edit command settings...
Find Default Layer to set the layer for all points that aren't controlled by DescKeys.
Expand Default Styles to control the styles of those points. If it is set to None, then these points will take on characteristics of the Point Group. If set here to something other than None, but you want the point group to control the display, in the Point Group Properties, go to Override tab and click overrides for Style and Label Style.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you both for the quick replies. My settings are set in those commands as Default Layer <use current> and under Default Styles to the style I wish.
But the points still come in on another layer C-PNTS-TEXT (not my choice) and the style is not what I set.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you look at the Command Settings dialog that Tim mentioned, is there anything in the Child Override column?
If you select one of these points and look at the Properties dialog you should be able to find out which point group it's part of. Does that point group have any layer or style overrides in it?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Double check your description keys to be sure you don't have a code that is picking up points you don't intend.
Post your drawing and ascii point file.
Redding, CA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No child overrides but it worked when I changed the selection of <current> layer to a specific layer and began a new drawing and reimported my points. The styles followed the defaults I set too.
