• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    IanMcClain
    Cogo Point properties window description format is forced lower case text
    76 Views, 2 Replies
    11-29-2012 02:34 PM
    Just switched to 2012 from 2010. When I try to edit the description format field in the properties window of a selected cogo point, I can't type in caps, it's all lower case. If I right click and edit the point, I can use capital letters, however. Anyone else seen this or know how to fix it?
    -Ian McClain
    (running C3D 2012 sp3, Win7 64bit)
    Please use plain text.
    Re: Cogo Point properties window description format is forced lower case text
    11-30-2012 09:26 AM in reply to: IanMcClain
    I'm getting the same results in 2012(sp2.1), but it works in 2013(sp1).
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    11-30-2012 10:18 AM in reply to: IanMcClain
    If you restart it should fix it. I'm sure sure what triggers this but it comes and goes for me.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
