• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Re: Civl 3D Polylines
    05-31-2012 08:55 AM in reply to: ctbailey
    It would not use the contours to create a surface.
    Please use plain text.
    Active Member
    Re: Civil 3D Polylines
    05-31-2012 08:56 AM in reply to: shunter62
    I have used a work-around.
    Active Member
    05-31-2012 09:00 AM in reply to: johnm
    Thank you. He uses SurvCadd, which I used to use also. I think they will all write XML files. I just find Civil 3D to be so much more difficult than either SurvCadd, LDD or even EaglePoint, all of which I have used. I don't see why something that should be straightforward has become so complicated.
    Active Contributor
    shunter62
    Civl 3D Polylines
    05-31-2012 10:09 AM in reply to: lex123456
    You are correct, Civil 3D does not accept LDD contours as a surface. It's better to ask for the original DTM or build your own surface/contours with the points and any breaklines you can devise. Susan H
    johnm
    05-31-2012 10:29 AM in reply to: shunter62
    Explode aeccontour objects once and polylines will remain.
    The best bet is still to get the xml. Look at the time it would have saved the OP. The design could have been in the workings a minute after the files were sent.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Active Member
    05-31-2012 10:57 AM in reply to: shunter62
    Can you tell me if there is a way to enter stuff into the profile manually by station and elevation?
    05-31-2012 12:20 PM in reply to: lex123456
    LDD is just as complicated as C3D.  It's just different.  Until you've figured out that C3D is not LDD or any of those other packages, you will be disappointed.
    Civil 3D 2013 x64
    Civil 3D 2014 x64
    Windows 7 64-bit
    6GB RAM
    Active Member
    05-31-2012 12:24 PM in reply to: engrtech
    Believe me, I have figured out that it isn't like the others. I just don't think I like it.
    06-01-2012 07:59 AM in reply to: lex123456
    You can create a design profile by station and elevation using the tabular editor; a button within the design profile toolbar.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Active Member
    06-01-2012 08:14 AM in reply to: mathewk
    Good to know. Thank you.
