AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Civil3d 2013 SP1 problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Fortunately, so far, I don't need to use 2013 very often. However, when I do, this has become more than annoying...yet I have not seen one other post regarding this so I'm trying to determine why me and not others.
The issue....C3D starts right up into my template drawinga s it should. I open a drawing, ANY drawing, and it loads fine, looks like it's all done loading, except....The cursor will not go into the drawing canvas, or, more correctly, it disappears. I can move the mouse over the Toolspace, ribbon, command window, but I cannot select anything in toolspace or type anything into the command line. What I CAN do is select a command from the ribbon and that will kick C3D back into a usable mode. At which time, anything I had typed into the command line appears.
Again, this happens everytime I start C3D2013, in the first drawing opened after starting. Susbsequent open attempts are all normal.
It is almost like there is an unseen message box waiting for input is in control, yet I've not found anything using any of the normal re-center dilaog techniques. Pressing Enter or Esc does not work. ANd this has only occured since the installation of SP1.
Anyone else seeing anything like this?
Re: Civil3d 2013 SP1 problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Correction, I can select things in Toolspace, but making changes (such as changing which style a surface uses) does not take affect until C3D is beat into submission.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Jeff, I haven't seen that error, but I did run into a situation where I moved the crosshairs to the top of the drawing window and then they disappeared and came back up the bottom. The only way to get to the ribbon was to move over the toolspace and then up.
Restarting Civil 3D fixed it and I haven't seen it again. A client was sitting with me when this happened and he said he has seen the same behavior.
Maybe Civil 3D 2013 SP1 has mouse issues?
I am using Microsoft Intellimouse Explorer. What are you using?
Tim
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm using a Logitech M510 wireless, Tim.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Haven't seen this, but I have another problem. While using the 3DORBIT command, zooming in and out doesn't work anymore, everything just dissappears off the screen. Panning around it seems as if the whole drawing has panned off to one side. This didn't happen prior to installing SP1. I've tried with the hardware acceleration off and on and as I do a lot of earthworks modelling this is so serious to me I'm going to reinstall getiing rid of SP1 when I have a chance.
Using a Clevo Notebook, i7 3720 3.0 Ghz 8 core, 16GB RAM, 256GB SSD, 750GB Hybrid HDD, Nvidia geForce GTX 680M 4GB, Logitech G700 mouse
Surveying & Management Services
Gladstone Australia
Clevo Metabox 16GB, Intel i7-3720QM 3.1Ghz, 256GB SSD, Nvidia GTX 680M
AutoCAD Civil 3D 2013
