• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Civil3D freezes if multi-tasking on startup
    317 Views, 5 Replies
    03-28-2011 08:38 AM
    This is a 2nd post. When trying to post a message while using Explorer 9, it is empty. Anybody else have this issue? Anyway, I've switched to compatability mode to see if that helps.
    I have this issue with 2 installations of Civil3D 2011-64 bit. I have 2 monitors. When first starting up, while Civil3D is loading, if I move to the other monitor and do any activity with the mouse, once civil3D is loaded, it is frozen. I can't do anything with it and need to use Task Manager to close it. If I just leave the mouse alone until Civil3D completely loads, then I'm fine. Just a minor annoyance, but have never experienced it with earlier versions.
    Tom
    Please use plain text.
    Product Support
    AlmasSuljevic
    Re: Civil3D freezes if multi-tasking on startup
    03-28-2011 09:28 AM in reply to: lsssurvey
    Hi Tom,
    Once that happens see if you can go to Task Manager and kill WSCommCntr<number>.exe Process. See if that helps.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Please click on "Accept as Solution" if post helped you resolve the issue.
    AllenJessup
    03-28-2011 09:33 AM in reply to: lsssurvey
    I don't have IE9. But I've seen others have the same issue with blank posts when using it.
    Allen
    Active Contributor
    03-28-2011 11:36 AM in reply to: AlmasSuljevic
    I will give that a try next time. Thanks.
    Tom
    Employee
    hgohel
    03-28-2011 11:40 AM in reply to: lsssurvey
    lsssurvey wrote:
    ...once civil3D is loaded, it is frozen. I can't do anything with it and need to use Task Manager to close it.
    Tom
    Once you bring up Task Manager, try "Switch to" Civil 3D task rather than killing it.  Does it return focus to the application?  I've seen that work in a particular case with C3D 2011, and it may work for you.
    Himanshu Gohel
    Autodesk, Inc
    New Member
    vanessa
    11-09-2012 06:42 AM in reply to: AlmasSuljevic
    I have been having the same issue with Civil 3D 2011 and Revit 2012, and this worked.
