• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    bmyers
    Civil Service pack / update
    268 Views, 8 Replies
    02-11-2010 12:11 PM
    My client is attempting to install the Civil 2010 sp2 onto a 64 bit machine. She had no problems with installing Civil 2010, but the update/service pack reads:
    civil2010sp2.exe is not a valid Win32 application.
    An thoughts on how to get it to install in a 64 bit environment?
    Brian Myers
    Sr Applications Engineer - Autodesk Revit Architecture Certified Instructor (ACI)
    Seiler Instrument, St Louis MO
    Please use plain text.
    *wfb
    Re: Civil Service pack / update
    02-11-2010 12:28 PM in reply to: bmyers
    For starters:
    There are two civil programs Civil 3D and Civil.
    She has to get the correct one. They have to match.
    Bill
    wrote in message news:6335052@discussion.autodesk.com...
    reads:
    *neilw
    02-11-2010 12:40 PM in reply to: bmyers
    If you get the wrong service pack, the error message is different Bill. It
    will say something to the effect of "No valid product installed".
    Active Contributor
    bmyers
    02-11-2010 12:42 PM in reply to: bmyers
    That was actually my second question. I've been able to verify that she has the correct one, this one is Civil 2010 (not Civil 3D). I also have a screen shot that verifies the message, but it's the same as what I typed (civil2010sp2.exe is not a valid Win32 application.) except with a file location. At first she tried it from her network location, then I had her move it to her PC. Same results.
    Does it need to be in a (x86) directory to install?? I doubt it, but I'm just throwing ideas out there. I don't have a 64 bit machine to test it on. Edited by: bmyers on Feb 11, 2010 2:43 PM
    Brian Myers
    AllenJessup
    02-11-2010 12:54 PM in reply to: bmyers
    Is it possible that the download was interrupted and the file IS invalid?
    Allen
    Active Contributor
    bmyers
    02-11-2010 01:01 PM in reply to: bmyers
    Wow, that answer is so simple and elegant I never even thought of it. Usually that would provide a different error, but its worth a shot.
    Brian Myers
    Distinguished Mentor
    02-11-2010 01:10 PM in reply to: bmyers
    I managed to install Civil 3D 2010 Service pack 2 on Vista 64bit with no problems. Ran it from the my documents\Downloads folder if memory serves.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    *wfb
    02-11-2010 01:17 PM in reply to: bmyers
    Thanks, Neil
    I guess we can leave it up to Joe. He appears to be an expert in all phases
    of problems.
    Bill
    "neilw" wrote in message
    news:6335032@discussion.autodesk.com...
    Active Contributor
    bmyers
    02-11-2010 01:49 PM in reply to: bmyers
    Well I'll be... the answer was.. the downloaded file was corrupt. :-)
    I love it when a plan comes together.
    Thanks!
    Brian Myers
