Does anyone know how/where I can reload my civil materials back into my drawing?
All of my civil materials are missing from the tool palette and I have no idea where to locate the folder so I can reload them into my drawing.
Solved by vberinger. Go to Solution.
Have you tried going into the "grey" area to the left side, right click and checking the one you want to see?
David
Yes, I am selected on Civil materials. I used to have tons of selections to choose from and now I only have 3 types. I need to figure out how to reload them and where to load them from.
If you type MATBROWSEROPEN in the command bar, it will bring up the Material Library. You can drag and drop it into your drawing or right-click and you get additional options.
If you use the AutoCad help, under the contents if you type MATBROWSEROPEN, they have a bunch of information under BROWSE MATERIAL LIBRARIES.
