AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Civil Imperial Subassembl ies not working
- Highlight
- Email to a Friend
We have been using Civil3D 2013 for a few months now and yesterday was the first time for me to try and use it to create a roadway assembly. I ran into a big problem, the Civil Imperial Subassemblies toolbar has no commands associated with it. All the parts are shown on the toolbar on each tab but there is nothing associated with them. I have included a picture of the properties of the Basic Lane part for you to see what I find. I also tried to enter the command CreateAssemblyTool with no luck. Civil3D does not recognize it. I made sure I was up to date on all patches and fixes and ran a repair of the program as well. Still no joy. I did not have this problem with Civil3D 2010 when I used these commands. Everything was there and worked great. Any suggestions or ideas?
Sid.
Re: Civil Imperial Subassembl ies not working
- Highlight
- Email to a Friend
Hi Sidney,
Please check that under the subassembly properties, they are pointing to:
C:\ProgramData\Autodesk\C3D 2013\enu\C3DStockSubassemblies.dll
As this image shows:
http://screencast.com/t/nmx07QXe
Americas AEC Infrastructure Product Support Specialist
Autodesk, Inc.
- Highlight
- Email to a Friend
Could this have happened after he installed his new version and he let the settings migration run?
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Highlight
- Email to a Friend
Good Morning Tatiana,When I try to access the tool properties all that shows up is what is shown on the image in my original post. I have checked other toolbars and I get the same results. The toolbars that show what your image shows are as follows:
Civil Multiview Blocks
Annotation and Design
3D Make
Generic Make
Cameras
Visual Styles
Samples
The rest of the toolbars do not have anything else associated with them. I do not know what else to do to fix this problem. Any other ideas?Thanks.
Sid.
- Highlight
- Email to a Friend
Hi Terry,
I am not sure what you mean by letting the settins migration run? Can you explain this process a bit more please.
Thanks.
Sid.
- Highlight
- Email to a Friend
mauserp08 wrote:Hi Terry,
Thanks.
Sid.
It's Tim, notTerry, but I've been called worse!
When you install a new version and run it the first time, a settings migration dialog appears. If you just press OK, the settings from an older version are migrated up to your new version. I am wondering if perhaps the OP pressed OK and it messed up his subassy pathing.
Tim
Redding, CA
- Highlight
- Email to a Friend
Hi Sid,
OK, so none of your tool palettes are working... Correct?
Please check this path under Options -> Files tab, Tool Palettes File Location:
This is the default location:
C:\Users\USER_NAME\AppData\Roaming\Autodesk\C3D 2013\enu\support\ToolPalette
If this is pointing to any other folder it could be something wrong on the software configuration.
Please post an image of your Support File Search Path
Autodesk, Inc.
- Highlight
- Email to a Friend
Tim,
I apologize for calling you Terry this morning. I really don't know why I did that. Call it not enough coffee and to early in the morning.
As for the migration issue, I still have 2010 and 2011 on my machine. The toolbars for the civil subassemblies still work in 2010 but not in 2011. I wonder if this is where the problem started and this set of toolbars did not get set up in 2011. Then when we made the move to 2013 it picked up on the setting from 2011. Now how to fix this is the question. Is there a way to change this as far as you know?
Sid.
- Highlight
- Email to a Friend
Hi Tatiana,
The toolbars that are working are listed in my post. The toolbars that are not working are the
Civil Imperial Subassemblies toolbar and the Civil Metric Subassembles toolbar. The rest seem
to be ok including the one I created myself.
Here is the support file search path that you requested.
Sid.
- Highlight
- Email to a Friend
Redding, CA
