AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Civil 3d hangs on startup when loading autocad civil3d ncs.dwt
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am running Civil 3d 2012 on Windows 7 32bit machine. Civil 3d crashed with error message not enough memory. I restarted machine, cold boot, now when i launch Civil 3D it gets to opening drawing c:\users\smh\appdata\local\autodesk\c3d2012\enu\te
This is really frustrating. Any suggestions.
Re: Civil 3d hangs on startup when loading autocad civil3d ncs.dwt
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
start with clearing out your temporary file directory - use windows explorer and "%temp%" (no quotes) as a shortcut to your user temp files. select all and delete.
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
check and see if you have your printers. if not restart the print spooled service this is an anoying problem. mostly with HP universal drivers and Adobe products.
Just a CAD Manager for a Civil Engineering firm...
Win 7 pro 12gb
NVIDIA Quadro 2000
LDD 2009
C3D 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Process Monitor (http://technet.microsoft.com/en-us/sysinternals/bb
Autodesk, Inc
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
tried the temp folder delete, but there are many folders with some old dates, and in one case when i tried to delete it said it's a shared folder and if i delete it it will no longer be shared. I don't know enough about the workings here so i canceled the delete operation. There is an etransmit () dwt that keeps showing up in the temp folder after trying to launch autocad civil 3d. I also have AutoCAD Map 3D 2012 on the same machine and it hangs when trying to load the map2d.dwt template.
Both programs are part of the AutoCAD infrastructure design suite.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
the link is bad, got another one?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
got the link to work, sorry
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Our office has had the same issue happen off and on. I have tried every solution and they have worked but temporarily.
Is there a new Service pack coming or does anyone know how to fix this for good???
JB
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1. From START>RUN and type REGEDIT
2. In Registry editor, browse to HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.0
3. Then find EnableCommunicationCenter on the right side, select it and set Value Data to 0 (to disble).
4. Restart Civil 3D
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That is done and it hung up this morning for the first time since I made the change...
JB
