• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Civil 3d and 7970m GPU problems
    195 Views, 2 Replies
    12-09-2012 08:51 PM
    I have started trying out Civil 3d 2012.
     When in 3d mode and rendering there is a lot of lag and my file has started to crash often.
    It is a relatively small job with about 400 drawing objects and 4 surfaces.
    My computer is a Metabox laptop p150em.
    Specs:
    i7 2.4 Ghz with intel 4000HD on chip
    16gb ram
    7970m GPU
    256 Gb smamsung 830 SSD
    Here is the 3D performance log:
    Performance Tuner Results Log
    Version: 19.0.1.00
    Date of Last Tune: 14/11/2012
    Version: 19.0.1.00
    Machine Configuration
    Processor Speed  : 2.4 GHz
    RAM              : 16274 MB
    3D Device
    Name             : Intel(R) HD Graphics 4000
    Manufacturer     : Intel(R)
    Chip set         : HD Graphics 4000
    Memory           : 1766 MB
    Driver           : 8.17.0010.1119
    Your machine contains a 3D Device that is not certified.
    As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website.
    You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button.
    Current application driver:    acaddm10.hdi
    Current Effect Status:
    Enhanced 3D Performance:   Available and on
    Smooth display:            Available and off
    Gooch shader:              Available and using hardware
    Per-pixel lighting:        Available and on
    Full-shadow display:       Available and on
    Texture compression:       Available and off
    Advanced material effects: Available and on
    Available application drivers and effect support:
    Software driver
    Effect support:
      Enhanced 3D Performance:   Not applicable
      Smooth display:            Not applicable
      Gooch shader:              Software emulation only
      Per-pixel lighting:        Not applicable
      Full-shadow display:       Not applicable
      Texture compression:       Not applicable
      Advanced material effects: Not applicable
    Autodesk driver:  Not Certified
    Effect support:
    As you can see its running off on chip graphics and not dedicated card.
    Ive tryed fiddling wth drivers to force it to use 7970m by disabling HD drivers but it still cant find 7970m, I assume this is because 7970m uses enduro and is normally off unless it senses 3d work. I have set CAD as a high performance program in catalyst also.
    I have also updated drivers but that causes more issues.
    Is there any way to force Autocad to pick it up?
    Also it appears that tune is dated awhile ago, is there a way to get it to re-run?
    Thanks very much
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: Civil 3d and 7970m GPU problems
    12-10-2012 12:24 AM in reply to: av135
    I would try to force running Autocad without enabled HW acceleration:
    1. edit the properties of the Civil icon on the desktop (or wherever you have it)
    2. add /nohardware at the end of the running string
    In other words, you should have something like this:
    "C:\Program Files\AutoCAD\acad.exe" /nohardware
    New Member
    12-10-2012 03:16 PM in reply to: av135
    Thanks tryed that, seems to run maybe a little quicker then the HD4000 with hardware excel turned off.
    Its still sluggish though, would really love to get my 7970m cranking.
    Thanks again
