• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Civil 3d Cooridor Sub-Assembly Tool Pallet Missing
    215 Views, 2 Replies
    01-09-2013 09:00 AM
    When I open up Cooridors/Sub Assembly Tool Pallets all the imperial and metric sub assemblies are missing.
    Does anyone have a fix for this?
    Please use plain text.
    *Pro
    Re: Civil 3d Cooridor Sub-Assembly Tool Pallet Missing
    01-09-2013 11:18 AM in reply to: ddade
    this was a problem with network installs of 2011 and there was a fix posted in the support section of the autodesk site.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Member
    01-09-2013 01:06 PM in reply to: ddade
    Check in your options under the Files tab open up "Tool Palettes File Locations", the default for Civil3D is:
    C:\Users\UserName\AppData\Roaming\Autodesk\C3D 201X\enu\support\toolpalette (for Windows 7)
    it should be missing if you are not having the imperial and metric pallets show up.
