• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Re: Civil 3d 2013 Point Classification
    12-18-2012 03:46 PM in reply to: tjplace1
    Plus 1 on Serivce Pack 1 still with issues.
    Civil 3D 2013 (SP1)
    Win 7 Pro x64
    DELL Precision Workstation T3500
    Intel Xeon 3.3GHz (w3680)
    24Gb Ram
    NVIDIA Quadro 2000 (1GB)
    Please use plain text.
    rjairath
    02-06-2013 08:38 AM in reply to: bkanthergolder
    classification failure with sp1
    Thank you for reading,
    Win7 64bit Pro
    Xeon E5-1620, 3.60GHz, 16GB Ram
    Please mark solution found if this post solved your issue or give kudos when appropriate.
    Valued Mentor
    gccdaemon
    03-04-2013 10:44 AM in reply to: bkanthergolder
    Same issue here as well, confirmed with SP1.
    Andrew Ingram
    Civil 3D x64 2012
    Win 7 x64 Ultimate
    I7 3820 (3.6ghz quad core with HT)
    32gig RAM (Corsair XMS3 4x8g)
    Intel x z79 mobo (BOXDX79TO 2011 socket)
    Radeon HD 7850 2gb GDDR5
    Member
    03-28-2013 10:30 AM in reply to: TJPlace8461
    Does anyone know if this issue is resolved in Civil 3d 2014?
    Employee
    osbornm
    03-28-2013 11:05 AM in reply to: TJPlace8461
    Yes, it should be working in 2014.
    Active Contributor
    04-01-2013 03:38 PM in reply to: osbornm
    Yeah... "Should be" and "Is" are two entirely different scenarios.
    Do you have any proof it is working?
    Regards
    Civil 3D 2013 (SP1)
    Win 7 Pro x64
    24Gb Ram
    04-02-2013 05:19 AM in reply to: osbornm
    With 2014 being backwards compatible to 2013, would that allow 2013 to display them correctly if it was done first in 2014?
    Civil 3D 2013 x64
    Civil 3D 2014 x64
    Windows 7 64-bit
    6GB RAM
    *Expert Elite*
    05-21-2013 11:40 AM in reply to: TJPlace8461
    Yes, I can confirm this works in 2014.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
