AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Civil 3d 2013 Drawing initial View
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Running 2013 on Vista 64bit I get the previews for drawings in the open file dialogue, looking at the tutorial drawings from both 2012 and 2013.
I also get the preview on a drawing saved from 2013.
After checking, I don't see the preview option in the views drop down in the open dialogue either in civil 3d 2013, but I still see the previews.
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I finally tracked down the registry location for the dialogue settings saved by civil 3d and found a setting which I am assuming controls the display of the preview.
The key location is
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\
Swap your current profile name for <<C3D_ANZ>>
and the key name is "PreviewVisible" and the value on my machine is set to 1.
Andrew Puller
Civil 3d 2013 64bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I appriciate the effort, but I checked that registry setting and mine is also set to 1. Still no view. I got an email back from my "trouble" ticket and Autodesk is now telling me "after more research, they found that it's a known issue and is in the hands of the developement team." There is nothing that can be done right now till the solution is found.
This is the 3rd issue that I've found thats a "known issue" and the development team is working on it. I'm VERY Frustrated with Autodesk personally. They need to quit pumping out the software so quick and make sure it works for the price everyone is required to pay.
Thanks for everyones efforts.
Steven
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
harshbarg wrote:I appriciate the effort, but I checked that registry setting and mine is also set to 1. Still no view. I got an email back from my "trouble" ticket and Autodesk is now telling me "after more research, they found that it's a known issue and is in the hands of the developement team." There is nothing that can be done right now till the solution is found.
Steven
These sentiments have been echoed several times in the past and I totally agree - they seem to concentrate on the "interesting stuff" rather than getting a solid core product.
My personal gripe is that they broke the DRIVE command in 2012 SP1 and although it works fine again in 2013, there is still no fix for 2012 possibly suggesting that this a little used command??
(No connection with Autodesk other than using the products in the world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My preview doesn't work either in the open window but works like it should in the Saveas window, where I really don't need it. I just tried a repair and that didn't work. I really don't want to reload. Where's service pack 1?
Windows 7 x 64
AMD Phenom II X4 945 3.00 GHz
16 GB RAM
NVIDIA Quadro 2000
Civil 3D 2013 (G.114.0.0, SP1)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Autodesk doesn't call them "Service Packs" anymore, that would imply the program is broken. For some reason, Hotfix 2 was on the website, and then removed. Not quite sure what happened or why it was pulled. But I was able to download it, and install it without issue.
I still have no drawing preview and not quite sure what the Hotfix 2 did.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Autodesk told me to edit the registry and it worked. I now have a preview on open.
Here is the steps they said to do which appears to be the same as Andrew's:
-Find and select this registry key:
-On the right side of the window, double-click "PreviewVisible".
-Change the value to zero and click OK.
-Launch Civil 3D and check the OPEN dialog window. The entire right pane should be gone.
-Exit Civil 3D and then go back into the registry and change the value of PreviewVisible back to 1.
-See if Civil now shows a preview.
This worked for me but I still wonder why it was set to 0. They said probably an install or profile problem.
Windows 7 x 64
16 GB RAM
NVIDIA Quadro 2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you tried the suggested fix posted above? What version of the software are you running? Include what service pack you're on.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for posting the solution.
My Civil 3d ended up not showing the preview for the open dialogue but was showing for the save dialogue the same as you had.
Your posted fix corrected this for my machine as well.
Andrew Puller
Civil 3d 2013 64bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This does fix the problem but it keeps happening to me and I can't figure out why. I've installed the service pack and it still occasionally happens. Luckily when I go into Regedit it defaults to the folder so it's a quick fix. Maybe it will be fixed in 2014.
Windows 7 x 64
16 GB RAM
NVIDIA Quadro 2000
