AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Civil 3d 2013 Bugs / Glitches
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've lost the ability to display NE coordinate point labels in 2013, it will show the point style but not my text label.
Did it all the time in C3D2012 but its not happening in C3D2013.
It's there in the properties dialog box with all the values but will not display on my screen.
I've check layers on, tried different fonts and sizes, made sure "true was toggle where it needed to be in the label style,
the correct coordinate system was active in drawing properties, UCS world was correct, transparency settings etc..I'm at a lost....
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The 3 R's ?
1. Restart
2. Re-Boot
3. Repair
Bill
Re-install would be later.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There's also the usual problem... For every bug Autodesk fixes in each release, they seem to introduce at least one more. Very frustrating. Especially considering every release is incompatible, and many people are forced to work in multiple releases, in order to collaborate with other companies. It's very hard to keep track of what bugs are in what releases.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Add to those:
1. tilted Cube with coordinate systems assigned to the drawing. the Cube shows sometimes as bottom even if it is the top.
2. Surface Legend Tables do not update dynamically when the surface data changes.
3. Viewport Type Choice does not work.
4. Civil 3D objects do not use transparency anymore, so no more overlays with imagery for surfaces analysis.
5. Dragged State for arrows thru the xref does not change based on the styles.
There are more, but could not think about them all at this moment of night ![]()
Web: www.civildigest.com Twitter: @C3DIsh
CAD Manager
Tom Groll Engineering
Email: ishka@tg-eng.com
Blog: http://www.civildigest.com, Twitter: C3Dish
Windows 7 x64, IDS 2014, 2013 & C3D 2012
Intel i7 930 @ 2.8Ghz, 12GB RAM, Nvidia GeForce 9600GT
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have also experienced several issue listed so far. Here is another: I edit a DWT (specifically Parts Lists), save, exit. Upon reopen, all the changes have been lost. No errors or warnings were given when I closed the DWT. There seems to be a SAVE bug. Maybe related to this topic: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Dat
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Are you talking about the pipe networks parts list? If so, I believe that is not saved in the template, but in a separate file.
The command AECCSETNETWORKCATALOG will check which file each machine is pointed to.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Parts lists are stored in the drawing. Parts catalogs are not.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I got logitech to send an old copy of the software that includes the 'middle button' option. It works great in 2013 for panning!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have issues with the layer properties manager. There are issues when creating new layers and renaming them in the properties manager. This worked flawlessly in C3D2010. Note that I experience this issue adding/renaming layers in a group filter view (my default work habit). I have not tried in the All Layers view.
-Jeff
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When working with Style based pen settings, feature lines and alignments that are externally referenced take on the xrefs layer plot style instead of the objects plot style. So a design can only have one lineweight once xrefed. So far only a problem with feature lines and alignments, surface styles are fine. Also does not matter if the style properties are set to ByLayer, ByBlock or a named plot style.
Civil 3D 2013
Windows 7 64-bit
Xeon W3550 3.07 GHz
Nvidia Quadro 4000
12.0 GB RAM
