• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Civil 3d 2013 Bugs / Glitches
    3985 Views, 29 Replies
    05-14-2012 08:06 PM
    Been working on C3D 2013 for a few weeks - not sure if anyone else is having these problems:
    • When zooming in/out using mouse wheel, cad doesn’t recognize past the first scroll intellizoom and places hundreds of ‘group of commands’ where the single zoom should be noted as ‘one’ intellizoom.  (Settings are set to combine pan & zooms).  The undo command limit is reached during a short drawing session due to this.  This is a major issue for me.
    • When isolating a polyline (and deselecting a feature line or other object) – autocad crashes.
    • Can’t print the model network plan view from ssa – it has a code error everytime.
    • Display of masked object (surface labels) in layout tab viewports (dark brown color behind text) issue.
    • When editing quick properties in cui, upon exiting, the toolbars are moved off-screen on the left side adj to docked ‘properties’ (they’re locked).
    • Unable to read the Object Data from the selected Autocad entity error pops up randomly, but doesn't affect anything.
    • In layout tab with a rotated viewport – ortho reverts back to original ucs during move/copy command while zooming in/out.
    Please use plain text.
    Re: Civil 3d 2013 Bugs / Glitches
    05-15-2012 05:52 AM in reply to: 9civil3d
    I have the issue "Display of masked object (surface labels) in layout tab viewports (dark brown color behind text) issue."
    I've been working with support at Autodesk on this. This only occurs when "display plot styles" is checked in the page setup manager. Can you verify this for me by unchecking this option and sharing your results?
    I am also having issues with C3D reverting to UCS settings that I haven't used or are just whacked out.
    Looks like I am not having as many issues as you are.
    -Dustin
    Civil 3D 2013 64 bit SP1
    Windows 7 Pro 64
    Intel Xeon 2.93GHz
    24GB RAM
    NVIDIA Quadro FX 580
    explodetheblock.wordpress.com
    Member
    05-15-2012 07:55 AM in reply to: dasindog
    box was already unchecked in page setup manager, still brown.
    05-15-2012 01:50 PM in reply to: 9civil3d
    1.) This is probably an Autocad problem, but the new command line never remembers its width between sessions. I can have it farily wide, save the workspace, close C3D, reopen C3D and the command line is back to being extremely short.  Not a deal breaker, but annoying as hell.
    2.) Map issue with GeoTIFF header information being ignored. Raster Design and Map ignore the units.
    3.) General lack of documention or notification about changes.  There was no mention in the help files or anything about Map now being able to reproject images to match your current drawing coordinate system.  The survey figure properties have a button to convert a vector-based figure to a chain-based figure, but there's nothing in the help files talking about what this is and why it's even in 2013 in the first place.  Aren't all figures already vector based as well as pretty much everything in Autocad?  There's also nothing really mentioning that with 2013 there is a new version of the survey database, so if you migrate a project you cannot ever go back.
    As with the OP, I have also noticed that the undo menu gets full of "Group of commands" extremely fast, even when hardly any commands have been executed.
    I've been using 2013 for small things, but I'm not recommending it for our company until a bunch of these issues have been resolved or workarounds figured out.
    Civil 3D 2013 x64
    Civil 3D 2014 x64
    Windows 7 64-bit
    6GB RAM
    *Expert Elite*
    05-15-2012 09:18 PM in reply to: 9civil3d
    I'm still trying to figure out why I can't get my MX Anywhere mouse to work in C3D...  It USED to, back on my old laptop with C3D2009-2011, but now I can't Zoom Extents or Pan.  And yes, I've gone into the "Application Specific" SetPoint settings and set Button 3 to "Autoscroll" for acad.exe, which is how I got it to work before.  Has no effect now in C3D 2012/2013, however...  It's been yet another of those "upgrade annoyances" I haven't yet figured out...
    Sinc
    05-16-2012 05:26 AM in reply to: Sinc
    Is "Autoscroll" the same as middle button for the MX? I have a Logitech M705 and in order to get the wheel button to work correctly I had to set it to middle-click instead of scrolling.
    Civil 3D 2013 x64
    Civil 3D 2014 x64
    Windows 7 64-bit
    6GB RAM
    *Expert Elite*
    05-20-2012 07:35 PM in reply to: engrtech
    Unfortunately, the MX Anywhere doesn't seem to have a "middle click" setting.
    And "Auto-scroll" always USED to work, on older versions of C3D...  Not sure what changed, but it's yet another of those frustrating things I have to deal with for every yearly upgrade.  STILL haven't solved the problem.  I hope it's not another of those "he said, she said" things...  (e.g., Autodesk says it's Logitech's problem, while Logitech says it's Autodesk's problem...)
    Sinc
    Active Contributor
    RobRaminsh88
    06-07-2012 06:09 AM in reply to: Sinc
    The mouse scroll / extensive undo lists are driving my office crazy!  A resolution to this issue asap would be greatly appreciated.....
    Rob
    New Member
    christian.barrett
    07-12-2012 04:41 PM in reply to: 9civil3d
    On the pan and zoom combo; do you have the combine pan and zoom commands turned off in options, on the user preference tab?
    Active Contributor
    RobRaminsh88
    07-13-2012 07:18 AM in reply to: christian.barrett
    Amazing!  You are considered an autCAD shink in our office right now!  Thanks Christian.
