AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Civil 3D crashes when saving a drawing
- Highlight
- Email to a Friend
When I save the drawing it crashes, only happens in 1 drawing. Recovers fine, but has 1795 errors, but can't save it will still crash, but saves the changes just have to recover again. Have tried Auditing, Purging, -Purge, Proxygrafics set to 0 per something I read when I searched this problem, short of wblocking everything out and putting it into a new drawing, any other suggestions? Noticed also I have to type in filedia and set it back to 1 everytime as well.
This company brings things in from everybody, so I'm sure it flooded with all sorts of diffrent apps info. Even though I keep telling them only take what you need they dump the architects, mechanical, landscape, everybodies drawings into 1 design file, not using xrefs, for even the survey is blocked in. Only other thing in this drawing a 1 png file and a pdf. This drawing also contains over 20 layout tabs alot but don't think it causing this problem. If your wondering dwg size its only 4mb.
Brandon
Re: Civil 3D crashes when saving a drawing
- Highlight
- Email to a Friend
you mentioned -PURGE - did you purge registered applications (REGAPPS)? with the third party stuff going on this may be it. I have had issues with polyines/2dpolylines/3dpolylines in the past - how autocad interprets these objects that were created by third party software. hatches are another culprit. if it were me, though, I'd probably copy/paste into a new dwg and take it from there. does the error follow?
David Renaud, RLS
C3D 2012 on 64bit Win 7 all up to date
Dell Precision 7core 8GB RAM
NVIDIA Quadro FX 1800M
LDT/C3D user since release 12
- Highlight
- Email to a Friend
Yeah made sure to exclusivly do -purge, regapps. Will look into the hatches, and linework see if it might be the issue, otherwise copy and paste see if it follows the drawing and see if it follows.
Brandon
- Highlight
- Email to a Friend
The problem ended up following the drawing, but used AECTOACAD command to drawing.
Brandon
- Highlight
- Email to a Friend
Did AECOACAD work?
I'm having the same crashing problem when I try to save. Tried auditing and purging to no avail. The file has to be corrupted somewhere.
Running Civil3D 2013 (AND LOSING MY FREEKIN MIND WITH THIS CRAP!!!!!!)
