I have a corridor model built and while i was trying to view/edit some the sections in corridor section editor, i noticed that it only shows three particular stations instead of the specified interval range. Attached is a plan view showing the partially builit cooridor roughly from station 3220+100 to 3200+300.
In section editor view, you can see the corridor edit tools are grey out. Under select a station, it will only show three station locations instead of the specified 5m interval.(see corridor frequency image)
I have several corriodr models built in this drawing and they are working just fine. For some reason this one does not. Any idea why this is happening? Thanks
Solved by ccookusi. Go to Solution.
It is because your stationing before the + is a large number. (Known Issue, see below)
I understand you are experiencing some issues with the section editor when dealing with an alignment that starts with a large number. This is actually a known issue that Development is currently working on, and I have linked this case to it.
The workaround for now is to create your stationing with a lower number as this should work fine without issue. I realize this may not be ideal, but it should get you back up and running.
I had it at 230+000 before and it worked fine. Try keep it under the 500+000.00 mark.
The larger the number, the worse it gets.
If one had a project that started at 10+00 and ended @ 90+00, it would be fine.
If it started at 1000+00 and ended at 1090+00, the threshold widens.
By the way.
This is only an issue in 2012 & 2013.
2011 works fine.
What am I supposed to do if my corridor is from 10+00 to 272+00? I can't really start any lower than that. So much for submitting plans today...
