• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    [Civil 3D 2013] Railway Double Track
    242 Views, 2 Replies
    01-06-2013 06:32 PM
    Hello everyone, First of all, I wish everyone : Happy new year ! I used a little bit Civil 3D 2013 for railway design purpose. I understood all the basics but I still have a question : how to implement a railway with double track ? In the library, there is only SingleRail subassembly. I'm not sure how to implement what I want or if it already exists in Civil 3D 2013. I found a topic (2006) : http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Rail-subassembly/td-p/1778412/highlight/true#.UOox_2-... But it doesn't really answer my question. Thank you for your help.
    Please use plain text.
    *Expert Elite*
    sboon
    Re: [Civil 3D 2013] Railway Double Track
    01-06-2013 07:39 PM in reply to: dyoxyne
    I'm not entirely sure of what your problem is.  You should be able to use generic links to add multiple rail subs to your assembly.  Perhaps you could use an assembly offset to have the second track follow another alignment/profile.
    Active Member
    01-07-2013 04:40 PM in reply to: dyoxyne
    Hello Sboon, Thank you for your quick reply. Actually I have a computer science background (and almost nothing in railway design). I don't know if it is better to choose : 1/ An offset alignment + 2 assemblies (SingleRail) 2/ An offset assembly + 1 assembly with 2 sub assemblies In a curve, there is a cant value. I supposed that each rail should have their own cant value and should be interpreted separately. So, is the solution 1 more simple and more suitable for that ? Or the solution 2 ? Perhaps the solution 1 and 2 can have the same results ? Sorry if my questions are not cleared.
