AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Civil 3D 2013 - Point marker with attributed block
- Highlight
- Email to a Friend
How do you get a point marker that uses a block with attributes to show the attributed text?
We are using tree symbols that have the size of the tree as an attribute, but when the points that use that block come in...the block shows up w/out any attributed text. Tried to edit the "block" or point marker with attedit command, but C3D tells me it is not a block. Understand that it is a "marker" for the point. But, what is stopping the text size of tree from showing up?
Any help greatly appreciated.
Re: Civil 3D 2013 - Point marker with attributed block
- Highlight
- Email to a Friend
attributes don't work thru point markers. use the point label style to show this text information.
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
6Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
- Highlight
- Email to a Friend
I see the options under the component name (Text, Line, Block). But, I do NOT see any options for attributes. Where does one find the options to add attributes to the label style for the point.
One solution a co-worker had was to explode the points. They've been causing some issues besides this one...
- Highlight
- Email to a Friend
Don't use attributes. Use the label to show the size of the tree.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
Basically, you point description becomes an attribute. Actually the attribute has grown up to the point description?!
Intel Core i7 2.0 GHz 2.0 GHz
8 GB RAM
Nvidia GeForce GTX460M
Civil 3D 2012 SP2.1
