• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Civil 3D 2013 Point Marker Rotate Grip
    168 Views, 1 Replies
    01-15-2013 08:19 AM
    In previous versions of Civil 3D there was a grip on the point marker that allowed me to rotate the block used as a point marker, where did this grip go in 2013? How can I rotate an individual point marker without having to create a separate point style?
    Please use plain text.
    sboon
    Re: Civil 3D 2013 Point Marker Rotate Grip
    01-15-2013 08:23 AM in reply to: KW-EGA
    The marker is still there, but it's now combined with the point movement grip.  Select the point and hover over the square grip - you should get a flyout menu with options for move or rotate.
