AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Civil 3D 2012 text
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Anyone having problem with text text when editing. It seems to hold it position after you edit and try to rotate or move the text?
Re: Civil 3D 2012 text
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes:
Here are a couple of options.
1. Convert to MTEXT
2. Run Audit with "Y" (sinc came up with this one.)
Bill
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here is another one. Run AUDIT (you may not see any errors) and then keep using ED command for editing of text.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is this a bug that may be fixed soon, is causing major problems. very unproductive.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think like you!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We are having this same problem. But have noticed MTEXT does not behave like this. Hopefully there will be a patch soon for this. I am getting tired of running the AUDIT command 100 tmes a day!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am getting sick of running Audit. Hopefully there will be a patch out soon.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try setting the DTEXTED sys variable to 1
Gary
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The city engineering team that I work for is also having the same text problem. As suggested, we tried the dtexted = 1 command and it gave us a dialog box for text entry. Unfortunately it would not retain the changes.
When we open the properties window and try to change the text we get a dialog box with the following message: "Object was open for read".
The only work around to break out of the open for read mode appears to be Audit.
This is getting extremely frustrating and really slows productivity. Please Autodesk give us a hot fix!
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm having the same problem, and can reproduce it on two separate computers (one workstation, one laptop).
It appears if you copy a piece of DTEXT, then text edit the original piece of text, it will get "stuck". You can't edit it again, and if you MOVE or ROTATE it dissappears until a regen. Audit, or close/reopen fixes it temporarily.
I guess switching to Mtext will fix it, but I don't like Mtext for everything.
