• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Civil 3D 2012 text
    3810 Views, 27 Replies
    05-06-2011 06:11 AM
    Anyone having problem with text text when editing.  It seems to hold it position after you edit and try to rotate or move the text?
    Please use plain text.
    *Expert Elite*
    Re: Civil 3D 2012 text
    05-06-2011 06:16 AM in reply to: aslove
    Yes:
    Here are a couple of options.
    1.  Convert to MTEXT
    2.  Run Audit with "Y" (sinc came up with this one.)
    Bill
    Product Support
    AlmasSuljevic
    05-06-2011 06:57 AM in reply to: aslove
    Here is another one. Run AUDIT (you may not see any errors) and then keep using ED command for editing of text.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
    Member
    mtecacad
    05-09-2011 03:38 PM in reply to: AlmasSuljevic
    Is this a bug that may be fixed soon, is causing major problems. very unproductive.
    Active Member
    stupidnguyen
    05-24-2011 05:35 PM in reply to: mtecacad
    I think like you!
    Member
    BYNUMFANYO8656
    05-25-2011 09:51 AM in reply to: stupidnguyen
    We are having this same problem. But have noticed MTEXT does not behave like this. Hopefully there will be a patch soon for this. I am getting tired of running the AUDIT command 100 tmes a day!
    Active Member
    05-25-2011 09:54 AM in reply to: aslove
    I am getting sick of running Audit.  Hopefully there will be a patch out soon.
    Active Member
    05-25-2011 01:22 PM in reply to: aslove
    Try setting the DTEXTED sys variable to 1
    Gary
    Active Member
    07-08-2011 08:53 AM in reply to: aslove
    The city engineering team that I work for is also having the same text problem. As suggested, we tried the dtexted = 1 command and it gave us a dialog box for text entry. Unfortunately it would not retain the changes.
    When we open the properties window and try to change the text we get a dialog box with the following message: "Object was open for read".
    The only work around  to break out of the open for read mode appears to be Audit.
    This is getting extremely frustrating and  really slows productivity. Please Autodesk give us a hot fix!
    Thanks!
    07-15-2011 02:01 PM in reply to: aslove
    I'm having the same problem, and can reproduce it on two separate computers (one workstation, one laptop).
    It appears if you copy a piece of DTEXT, then text edit the original piece of text, it will get "stuck". You can't edit it again, and if you MOVE or ROTATE it dissappears until a regen. Audit, or close/reopen fixes it temporarily.
    I guess switching to Mtext will fix it, but I don't like Mtext for everything.
