• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Civil 3D 2012 and Broke Google Earth import
    1049 Views, 5 Replies
    07-13-2011 08:40 AM
    Is there something different about 2012 Civil 3D that causes Google Earth not to work now.
    Has anyone else experanced the same problem?
    The image sometimes shows up but the topo seems to lock up every time.
    Did they change the setting?
    Please use plain text.
    Employee
    hgohel
    Re: Civil 3D 2012 and Broke Google Earth import
    07-13-2011 12:07 PM in reply to: bham4ever
    Could you post the steps to reproduce the problem you are experiencing?
    What is the version of Google Earth you are using?
    Himanshu Gohel
    Autodesk, Inc
    Distinguished Contributor
    07-13-2011 02:03 PM in reply to: bham4ever
    Have you tried checking these settings?
    - ImportGEData
    - ImportGESurface
    See here for more information:
    http://www.civil4d.com/2008/05/getting-around-the-surface-building-problem-with-ge/
    07-13-2011 02:23 PM in reply to: hgohel
    have dodn it the same as in 2011
    The setting set
    - ImportGEData
    - ImportGESurface
    just like it says in http://www.civil4d.com/2008/05/getting-around-the-surface-building-problem-with-ge/
    row and columns 70 70
    using 6.0 version of Google Earth elevations are on
    Member
    tch77
    07-13-2011 02:41 PM in reply to: bham4ever
    Try changing your drawing's coordinate system.
    For instance, NAD83(CSRS) / UTM zone 11N is broken in C3D 2012, but GE works fine with UTM with NAD83 datum, Zone 11, Meter, Central Meridian 117d W.
    Haven't tried it with surfaces, but doing that solved my problems with trying to import just an image.
    Valued Contributor
    07-14-2011 06:29 AM in reply to: bham4ever
    Civil3d 2012 was broke with Google earth on mine initially.  I finally had something that came up and said wrong version on Google Earth.  I uninstalled Google earth 6 and installed Google Earth 5 and it worked fine, so you may want to check and see what version you are using.
    Alan Neal, P.E.
    Autodesk Infrastructure Suite Premium 2012/2013
    Windows 7, x64
    Xeon E31225 w/ Quadro 600
