• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Re: Civil 3D 2011 runs slow and likes to "not respond"
    11-08-2010 10:25 AM in reply to: Bugpop
    Just a thought...
    Civil 3D writes an instance of the image to your local TEMP directory.  I have noticed serious performance issues with a cluttered temp directory.
    Please use plain text.
    11-08-2010 11:37 AM in reply to: bigblittlerent
    It does this when using the Autodesk FDO for Provider for Raster, however my regens are not unreasonable when inserting raster images in this manner.
    When I attach images in the reference manager or using Raster Design I am not aware of local instances saved to temporary directories.
    To be sure I have created new temporary directories for Civil 3D to use but the problem persists when images are attached in the reference manager.
    11-08-2010 12:11 PM in reply to: oceanside
    I cant even get into AutoCAD.  it freezes up before the application lauches.
    11-08-2010 12:31 PM in reply to: justin_hogan
    It's probably another issue
    Open up Task Manager and see if WSCOMMCNTR2 is still running.
    End the task
    11-10-2010 12:41 PM in reply to: bigblittlerent
    AutoCAD wont even load long enough to load the WSCOMMCNTR2  or maybe that is the problem it doesnt load the WSCOMMCNTR2???
    Just did a fresh install per Autodesk instructions and still not responding after it starts to load.  never gets to the splash screen.
    neilyj
    11-11-2010 05:51 AM in reply to: bigblittlerent
    ...and this is another thing that occurs all too frequently... and inevitably causes a lot of rework
    neilyj
    (No connection with Autodesk other than using the products in the world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    New Member
    nathan1899
    02-25-2011 05:20 AM in reply to: tfboles
    For me if I not disable but totally exit out of Norton my issues go away.  I believe Norton is stopping some of the processes in C3D.  C3D would start to "not respond" for many things that seemed unconnected but when I shut off Norton it fixed the issues.
    Civil 3D 2011 SP1
    Win 7 Pro x64
    4Gb Ram
    ATI Firepro 4800
    Dell T3500
    Valued Mentor
    gccdaemon
    02-25-2011 06:13 AM in reply to: nathan1899
    We're using Nortons Hosted Endpoint Protection and we don't have the long hangs like you guys are discussing.
    I am experiencing a problem with my graphics card locking up my OS and have to hard reboot, but that seems to happen in other graphics heavy applications IE Google earth.
    As for the not responding messages, those only pop-up because you're clicking on and off the program when it's still processing and doesn't not actually mean that autocad has locked up.
    Andrew Ingram
    Civil 3D x64 2012
    Win 7 x64 Ultimate
    I7 3820 (3.6ghz quad core with HT)
    32gig RAM (Corsair XMS3 4x8g)
    Intel x z79 mobo (BOXDX79TO 2011 socket)
    Radeon HD 7850 2gb GDDR5
    Active Member
    02-25-2011 06:42 AM in reply to: bigblittlerent
    It has become my routine to disable norton for 5 hours at a time.
    once the problem starts you must exit acad to stop it. (and possible reboot??)
    Disabling norton after the first occurance will not stop it
    02-25-2011 07:24 AM in reply to: tfboles
    Had a similar problem with AutoCAD and Inventor 2011.   Go to the control panel, add/delete programs, and click on the .NET framework.  When it asked to remove or repair simply click on repair.  This will fix it.
